0 Members and 1 Guest are viewing this topic. Read 22143 times.
How low does this extend the bass from them?
Nice So the woofers are actually on the back of a chamber, with ports directly opposite? I wasn't aware of that.
If you put EAR SD40AL constrained layer damping material on the woofer frames and also magnet brace both woofs and also brace the baffle with the same brace you will get much, much better bass. I cannot seem to figure out how to make a picture appear here so I will try and load it to my Gallery. The last pic in the gallery shows an alpha 15 in an h-frame with EAR damping material applied and also the magnet is epoxied to a piece of 13 ply plywood which is bolted to 26 ply plywood brace. You can use just one brace for both magnets and curve it around so it also braces the baffle between the woofs and full range. Way better sound! The Gallery also shows an open baffle speaker that also has both Alphas damped/magnet braced and the baffle braced....very crude version.
Dave,If you just want to brace the baffle then you can run trianguated braces up each side. Google the Granada G2 speaker. You could run a similar brace on each side but not all the way up.....just to below the full range. This would be plenty of brace and the full range would not have any cavity resonance to deal with if you ran it all the way up. A heavier base with the braces would add more weight and the combo would be really rock!!! and at the same time not rock. You don't want the speaker to move....just the cones. 5 inches thick......with Green glue.....yikes! This is good!
