0 Members and 1 Guest are viewing this topic. Read 51328 times.
There ya go...."it should" but not necessarily true....the circuit will only draw what it needs and 125 ma at 5 volts +/- % is all it needs...or it wouldnt be doing as well as it is..Your welcome to tack on a"BIG" power supply but this unit can get what it needs to be "beyond" inaudibility already...and any improvements to the already published specs...to put any of these measurements even further into the inaudible range...well ok....spend you money wisely.The whole idea and excercise was to do the best with the least...and its really as good as stuff costing a whole lot more bucks...I finally have my USB cable hacked and will run some tests on the actual current draw....and voltage drop on a few pcs..All the bestAlex
I wish I had known about the other diy builds before, I would have gonewith those.
I've since become more deluded and made more mods to the odac this time replacing some of the caps, based on observations made by others who have heard the odac (and had the same criticisms as I) as well as other builds based on the same chip (there were at least 2 other people doing their own design at the same time as NwAvGuy on diyaudio) and frankly at this point it does not sound anything like stock at all. We can do the measurement dance all day but in the end I have made all these changes, I have done the comparisons for myself and there is no way on God's green earth anyone would prefer the stock performance over what I am hearing now. It is a different dac in sound quality altogether. I wish I had known about the other diy builds before, I would have gonewith those. I understand your perspective and that's fine, I offer my experience for the curious. NwAvGuy's POV is the same found on every forum at least one a week regarding every component in audio from dac to speakers to amps to cables to wine so if my tinkering means no birthday card from NwAvGuy - oh well. Not even going to bother addressing his quote because then this thread will just deteriorate and I will have to go back to my hamster wheel avatar.
Just unpacked it and hooked it up.
i've heard is on par with the HRT streamer II+
Thanks for the insight. Can you share more info on your power supply and other mods?
Cool, enjoy reading about your 'upgrades' and 'pioneering' with your stuff.
