0 Members and 1 Guest are viewing this topic. Read 51310 times.
I am building a O2amp and will buy another ODAC and put them in a larger enclosure with batteries and AC as well and RCA jacks and a larger headphone jack...
I ordered a AC to AC adapter with a higher voltage/current capability.
I didn't realize that some people were not using the USB power. What does NwAvGuy say about this? Measurements are criticle as then it's no longer an ODAC.
Well *I'm* not and I think I am the only one. I was not impressed with usb power but then I'm using it for 2 channel and most people aren't which I think makes for a very different experience. as for NwAvGuy. Ha. Yeah. That's his problem. Onwards and upwards.
Nice Supply....however I don't really think this will really make any real world difference in what we can hear in our cans.If you look at the design and the real world analytical measurements nvawguy has posted and have been confirmed there is no real need for more power than can be provided from a a good functional working USB port...you only need 125 millamps of current!You don't need 10 amps.If you really hear sonic approvements with this supply, my hats off to you....but being the analytical guy I am I challenge you to do a blind test with someone else switching the power supplies , do this 10 times , record your 'honest' results...All the bestAlex
I'll be using it for 2ch as well. I have a Metric Halo LIO-8 currently so I'm curious....I guess what I'm saying is pretty much what Alex said. If the deisgner that has made the ODAC (Objective)DAC and proved that it doesn't *need* and external power supply then why not try to have measurements done to show what you might be hearing?
In High end audio - power supply is everything - IMO, it should benefit from better than usb power ...On the other hand - dragonfly is looking good for a usb powered - tiny dac/headphone amp ...
