0 Members and 1 Guest are viewing this topic. Read 51303 times.
ok so what your saying is to plug this gadget into the ODAC and plug it into the pc and leave it hanging off the pc....then attach your output cable to the amp....from the out on the DAC with a cable.So the usb cabe length is now gone but depending on where you pc is etc the cable from the output of the dac to the amp may be long or longer...etc
Yep. Note that I do not use headphones, I am using the odac to 2 channel speaker setup.
What other dacs have you compared it to?
I've compared directly with the Dragonfly, AMB Y2 DAC w/Hiface 2, and the leopold TDA1543 dac w/Hiface 2.
Do you feel that you like it best or is it still on par with the Dragonfly as long as you use the small adapter? I'd like to hear one of these. The measurements really are great.
To compare you really need to do USB to USB etc....adding other stuff or conversions or adapters etc. muddies the water...as we all know...I will compare USB to USB. Same source, same PC, same WASPI etc...try to keep things as the same as humanly possible, I will also ask some friends over to help do some 'blind' switching out and see if i can hear any differences without any biased emotions creeping in.....its hard..Alex
Well, I think it's quite possible that any comparison involving one of NwAvGuy's designs has "expectation bias" built in - one way or the other - due to the rather interesting "press". I'm thinking I'll get an O2 - it should be interesting, as in theory, it's completely neutral. See, there I go, setting myself up...
The ODAC has shipped!!! Just a few days away from testing!!!Alex
Here is the ODAC in a case with RCA outs and the mini jack up front....just completed this one...Works very well, and I will now try it in the 2 ch rig....Next project is to build an AC only desktop with the O2 amp and ODAC in the same box..Alex
