0 Members and 1 Guest are viewing this topic. Read 356797 times.
If one takes the time to read the comments on the mains supply made in various places by Bruno, you will find that recommends straight into the wall without any sort of treatment, filtering, etc.
Yeah, that didn't work out to well in my system. I wouldn't recommend it.
With all due respect, you are a cap, wire and tweaker while Bruno Putzeys is NOT. He's 100% science. It's up to each person to treat their build as they please but DO NOT make this thread anything more then your listening impressions. We have an NCore Improvement thread for that.
I sure could have used the Uber Buss here in my system when I tried out the Ncores. Even those $1K power cords could not filter out the AC grunge that I have coming into my house , with the amps plugged straight into the wall.Maybe an amp designer could come to my home town for the ultimate challenge.
In one way these amps proved to be just like every other digital amp out there in that they are really dependent on the power that you feed them.On the back panel was one of the really cheap IEC connectors with the built in on off switches right on the connection. There was a cheap RCA to balanced adapter being used, and the binding posts looked really cheap. Just from my own experience I know there are a lot of gains to be had from the obvious upgrades.
Pete, you never mentioned what your preamp was (tube no doubt) and what source(s) were being used. Thanks.Cheers,Robin
