0 Members and 1 Guest are viewing this topic. Read 25374 times.
How does the pre-amp play in the equation, or does it matter?
GR research servo subs / AE TD 12M's / Radian 745 1.4 CD ,cherry waveguide/ Fountek 3.5 Ribbon . All enclosures sand filled sealed low Q---96 db system powered by 8wt SET 300B's ----SUBs use SS servo plate amps I assume subs will be excluded from power limits.?? Low watt SET not having to do low bass is a good thing IMHO
Hey! Look like I will fit in this circle pretty nicely Take care,Buddy
I can remember when 40 wpc systems were considered HIGH power.
