Amarra best version
0 Members and 1 Guest are viewing this topic. Read 31712 times.
audioengr
Re: Amarra best version
« Reply #60 on: 17 Feb 2013, 07:11 pm »
Dear Steve
Thanks so much for the pointers! A few more questions if I may:
1. Do you no longer offer a battery power supply for your USB interface? If so, why?
No.  Bacause it was all hand-built and I dont have time for this anymore.  I dont sell enough of these to warrant contract assembly.
2. Have you compared your 2009 Mac Mini's (just missed pulling the trigger on one at auction, bummer…) audio performance to that of a Mac Book Pro (whose RFI rejection is said to be superior)?
No, but one customer with both likes the Pro
3. How important is the OS's ability to do handle files in integer mode (in other words, should one install 10.6.8 Snow Leopard instead of Mountain Lion on a dedicated music server)?
I am using Snow Leopard.  some have said ML sounds better, but my most reliable contact says no.
4. How does one play back files on a Mac Mini if no USB connections are ever meant to be used simultaneously, that is none apart from the one connected to the USB interface (no keyboard, no screen), with the WiFi turned off? (Only thing that springs to mind would be to connect the Mac Mini to the local network via Ethernet and use e.g. an iPhone or iPad via the "remote" app.)
I use bluetooth wireless keyboard and mouse and I dont bother turning off WiFi.  Some of these things have little or no effect IME.  Like 64-bit mode.  I cant hear anything....
Steve N.
acousticsguru
« Reply #61 on: 22 Feb 2013, 01:54 pm »
Thanks again, Steve!
Still on the look-out for a 2009 Mini. Curious: once you replaced the original HD with an SSD, what happened to the fan (noise)? Even assuming the temperature sensor is being reattached, don't those older models always run their fan at a minimum 1'800 rpm (if not higher)?
Greetings from Switzerland, David.
acousticsguru
« Reply #62 on: 22 Feb 2013, 01:58 pm »
By the way, do you use the in-built, or preferably an external drive to rip files? Asking this because I'm obviously looking at used 2009 late Minis.
audioengr
« Reply #63 on: 23 Feb 2013, 01:15 am »
I never notice the fan noise.  Its at my side, not in front.
I use a USB Teac slot drive to rip CD's.
Steve N.
grannyring
« Reply #64 on: 31 Aug 2013, 12:27 pm »
I have been using the Amarra version Steve suggests for some time now. I tried the 2.5 version and it sounds better to me. More body, improved tone and not as thin sounding. You may want to try it as I was quite surprised with the overall improvement.
The bass is full and has more impact. The bottom line to me is it is just more musical and less Hifi or digital sounding. The differences are not day and night here, but degrees.
This is the first time any version has sounded better than the 19 version we all enjoy. I am not referring to the 2.5.1, but the 2.5.
I use a Lampizator 4/4 dac and followed all of Steve's advice with a 2009 Mini, SW tweaks, SSD drive etc.... I have a Mojo Audio power supply on the Mini that made the biggest difference of all as an FYI to the group.
paul79
« Reply #65 on: 31 Aug 2013, 04:21 pm »
I think it is good also, but the focus is not quite as good with my system. I'm sticking w/4319. It is just more real sounding to me.
paul79
« Reply #66 on: 13 Dec 2013, 09:53 pm »
Tried Amarra 2.6 today and it is pretty good. It has a deeper soundstage and the detail is on par with 2.3.3. It has a quieter background in the music also, making it more immersive, so to speak...
The only 2 drawbacks are the center focus is not quite as fine tuned as 2.3.3, although close. The bass is not quite as focused either, but I will say that 2.6 is really good. If they could just sharpen up the focus, it would be a winner for sure. It did improve on a couple things over 2.3.3.
Still staying with 2.3.3 though for the time being.  It just locks in better  :)
paul79
« Reply #67 on: 28 Feb 2014, 02:33 am »
Thought I would share this here, as it pertains to Amarra...
I quickly realized that no TV or monitor plugged into the Mini made a nice improvement to the sound.
In order to do this, I had been using the Remote App for the Ipad, to control Amarra/ITunes. However, I like the Playlist function for Amarra, with my ever increasing library of music. I like the convenience of dragging the file into the Playlist, and done.
I found an App called PocketCloud, and I know there are others, and I'm sure I am late to this party, but this one works pretty good. It allows me to control the desktop from the Ipad.
So, you effectively improve the sound of the Mini by disconnecting the monitor, while being able to remotely control the Playlist feature of Amarra. Win Win!
rogerdn
« Reply #68 on: 1 Mar 2014, 01:01 am »
T
Paul79...Thks for the heads up on the PocketCloud (running JRMC however), it actually installed easily and is great, have been looking for something like this for some time. Will disconnect my monitor too and give a listen.
toddc2
  • Fritos? No thanks, we prefer shoes...
« Reply #69 on: 9 May 2014, 07:14 pm »
I have been using Amarra Symphony w/IRC since early January. Prior to that I was using the stock Amarra release. The integrated room correction in Symphony is killer good. It was a pricey upgrade but well worth it IMO.
rogerdn
« Reply #70 on: 8 Jul 2014, 02:15 pm »
Steve, assume you have listened to 3.0, any SQ changes/improvements ?  Can I get the best SQ with regular Amarra and the iRC add on or do I need Sym ?
toddc2
« Reply #71 on: 15 Jul 2014, 08:51 pm »
I think the IRC add on is a partial implementation called IRC(b) which does the lower frequency corrections. I had a chance to listen to Amarra 3.0 with IRC(b) when I upgraded to Symphony 3.0 and Sonic Studio sent me the wrong upgrade link. Based on that relatively short listening experience, Symphony with IRC is much better than Amarra with IRC(b).
The reason the listening experience was so short is that I knew within about 2 seconds something was wrong with the original upgrade, it really was that obvious.
Todd
rogerdn
« Reply #72 on: 18 Jul 2014, 01:13 am »
Thks Todd, after posting I learned on CA that was the case.
