Hi Frank,
I am assuming the Wireworlds are as well shielded as the Radio Shacks? As it happens, I have a couple of sets of the Radio Shacks that I'm using downstairs. I could give them a try.
Apart from the pre to amp IC, there is only one other IC I can change -- I am still using a braided silver IC from my DAC to T7. I assumed that was not a problem, because the (very, very slight) hum is still there when the power to the DAC and transport is turned off. However, I will try a shielded IC in its place and see what happens.
The remaining IC is integral to the the tone arm, and should be pretty well shielded.
The fancy silvers are a holdover from the passive "pre" I was using before the T7 -- very low capacitance, so they had their role there.
