0 Members and 1 Guest are viewing this topic. Read 63677 times.
Hi James,Will the DAC option for this unit utilize the Crystal DAC or the one used in BP26/6?Thanks,Mark
The Cyrstal CS4398 which we use in the BDA-1.james
Is the dac chip a double like the bda or single as the cd1?
So that makes it full fat 24/192 I guess?Does it come with either the BR2 or BR3 remote?Thanks,
James,the internal DAC works up to 192/24?al.
So it's the BCD-1 dacwise?
Hi No remote.james
James, with all due respect, why not just do a plastic remote?
James I'm missing something here. I thought the bcd1 dac upsamples to the higher rate. I know it's basically the redbook 16/44 but was set to the 96kz sample.
The BCD-1 oversamples 128 times I thought. I don't understand what James means by saying it's not oversampling. All the info says it is.
