0 Members and 1 Guest are viewing this topic. Read 17034 times.
Josh, I think we already went through this dispersion thing. As far as I know, the designer tried various ribbon widths and he deliberately chose 1" (25mm!)width, over a narrower one - on sound quality grounds, not measurements. With the exception of Magnepan 3.6 and 20.1, all other Magnepans have 2" wide planar magnetic tweeters, which is twice that of SoulSonics - do they perform suboptimal? What is the dispersion characteristics of all those big ESLs, or conventional boxed speakers, majority of which use 1" wide tweeters? Some people favor extremely narrow HF dispersion characteristic (example: Sanders ESL), because of the better image focus.Spatial aliasing - the four woofers are tapered array, which enables them to avoid the typical upper bass suckout that happens in smaller rooms with all other planar speakers.The cones are very light and fast, but the proof of course, is in the listening.Because the crossovers are shallow, the blending is excellent and the sound very homogeneous, you can listen from 7` distance with no problem.Their strengths: much more dynamic than typical planars, much higher sensitivity, more coherent than 3way planars, because there is no XO point in the very sensitive presence area, the dynamics in this region is much higher and more lifelike, the ribbon construction is very shallow (0.8"), which enables better dispersion than with other planar speakers that have ribbons in 3" thick enclosure, SPL are incredibly high with no apparent distortions, focus is great, natural tonal colors, etc.For pricing ask the manufacturer Soulsonic directly .
What is their sensitivity?
Ah, OK, thanks, didn't see that at the bottom.I saw another interesting glass baffle dipole in one of the CES reports, IIRC it got a glowing review. Not sure if it was by the same guy (or even the same speaker?).
Regarding the tappered array, I cannot disclose any further details (a trade secret), but if you consider yourself a potential buyer, then contact the designer directly and ask him.
