0 Members and 1 Guest are viewing this topic. Read 9968 times.
I'll try removing the stuffing in the center section, and will do the lining the walls. What's the name of that black thingy which Dave lined the wall? Egg crate? I should get some next time I go to WalMart.
When you lined the cabinet with polyfill previously, did you fill the center of the cabinet or just line the walls?I do apprecaite your response and sincerely hope that more folks will contribute their findings. If they contribute to my conclusions - good. If others find something that works better - great!Dave
My hunch is that Wool Furnace Insulation blanket is very fire resistant. I'm certain it's better than acoustic foam. This is likely why these products are produced.Owens Corning also has some Absorption numbers on their web site. The Master Handbook of Acoustics (Everest) has some numbers for various materials too. All of these are very tangible and usable. There are indeed methods to these numbers that have a VERY scientific basis. I think it's great that manufacturers can and do objectify th ...
Well, I did question Dave and he said not to remove any of the port tube, but instead to lengthen it.
