0 Members and 1 Guest are viewing this topic. Read 43535 times.
The problem with "acoustic suspension" is the distortion, especially when using a small woofer. If you try and squeeze too much bass out of it at some point the distortion becomes gross distortion.I'm not absolutely sure about their efficiency, but I'm thinking that woofers designed for acoustic suspension aren't all that efficient either, they have long throw, overhung voice coils, never a lot of turns in the gap.
Yes. Both harmonic and phase distortion. I've owned both.I have furnished some data to support my contention, based on a middle of the line (but well engineered) acoustic suspension speaker. Let's see some distortion plots for 70W input into your favorite phase inversion (the technically correct term for bass reflex) box. We'll see if they match the 30+yo Allison.There have been both good and crappy acoustic suspension designs, and good and crappy vented designs. I don't know what your blanket statement was based on. Driver and enclosure engineering have improved over the years but the laws of physics haven't.
My statements are based on the obvious market trend that seems to like ever smaller and smaller loudspeakers. That is the reason there are so many bass reflex designs. Squeezing bass from as small of an enclosure as possible. Like this little teeny tiny set of desktop computer speakers that are plugged into my computer. I don't use them for music appreciation, I just have them there so I can hear whatever it is they have to say, but the darn little things are actually ported!So, how would a 6.5 inch acoustic suspension design stack up against a 6.5 inch bass reflex design? The epitome of a two way is most often a 6.5 mid-woofer with a 1 inch tweeter in a bass reflex enclosure. I also wonder how the two would compare in the efficiency department. There must be a reason why acoustic suspension has slipped into near oblivion.Doesn't really matter what the phase is, as long as the port output doesn't cancel the woofers output. Never really a problem with a properly designed 4th order alignment.The more correct term which really makes sense, is Helmholtz Resonator.
Many of the speaker makers in acoustic suspension's heyday- AR, KLH, Advent and Allison come to mind- made their own drivers. Only a small handful do today and most of those are "deep end" ($$$$) boutique brands.
That seems different from the original argument, which as I understood it was that acoustic suspension fell out of favor due to high distortion levels. I wonder if Wayner is hearing high distortion from his AR's. I certainly didn't from the pair I listened to at length. It is a small 'bookshelf' model with an 8" woofer, so I wouldn't expect it to rattle windows in a big room, but a pair of Allison Ones (for example) would.I too have seen ported computer speakers. While some are certainly legit, I have observed some with ports that are about an inch and a half deep. I haven't done the calculations to determine the resonant frequency of a one and a half inch deep port, but I have a dollar that says it's well above the bass range. It's there because people expect to see a port these days. In other words, it's there for marketing reasons, not for any acoustic reason. I am just saying that that marketing reasons have something, maybe not everything, to do with the disfavor acoustic suspension has fallen into. Many of the speaker makers in acoustic suspension's heyday- AR, KLH, Advent and Allison come to mind- made their own drivers. Only a small handful do today and most of those are "deep end" ($$$$) boutique brands. So most speaker companies today outsource their drivers and are basically designing the enclosure and crossover around available drivers. And when driver manufacturers gear their product line towards what sells- a driver suitable for acoustic suspension has very different characteristics than one suited for a ported box- a snowball effect ensues: fewer sealed designs>fewer suitable drivers offered>even fewer sealed designs. The speaker driver manufacturer has a mortgage to pay too.I believe the port tube is a Helmholtz resonator and 'phase inversion' refers to the enclosure as a whole, but I don't want to get bogged down in terminology. I just wanted to challenge the assertion that acoustic suspension=high distortion.
Full interview at http://www.stereophile.com/interviews/105villchur
Thanks for the link, dB - a good read. He, along with Henry Kloss, are two of my heroes in American Audio.
Try giving an acoustic suspension design some baffle step correction and see what happens to the distortion.
Let's see some data.
Bass Reflex vs. Acoustic Suspension,,,, CD vs. Vinyl,,, .... when will we outgrow these silly arguments?
