Since my last post, I have been buying more vintage Seas gear.
For 20 GBP, I purchased a pair of Sony S-2030, from late 1970s.
See this website for pictures of boxes and drivers:
http://www.audiovintage.fr/leforum/viewtopic.php?f=20&t=9071Each box have a Seas 21F-GWS, 10F-LGS and 5TV-HFS. All 8ohms.
My initial plan is to use this speaker as a mid-treble box sitting on a separate bass box.
I am saying box, because they will look like boxes but in fact be open baffled.
First I will cut open all sides of the Sony speaker except for base and front,
leaving the 3D skeleton intact. And then I will wrap the whole thing in speaker cloth making it look like a box.
The bass boxes will be boxes but with open backs.
I will place sorbothane feet between bass box and mid-treble box for isolation.
I might replace the ferrite 21F-GWS with the alnico 21TV I have.
I would love to use the 9TV instead of the 10F, but the 9TVs I have are 16ohms.
Can this be done by changing the crossover components?
Now to the more difficult bass box:
I am now the proud owner of a total of 8 Seas 21TV-EW s.
From behind, these look exactly same as the other 21TV I have.
The difference in the front is that EWs have rubber surround and thus a much higher excursion.
The Fs is said to be 30Hz and sensitivity at around 89db.
The mids on these things are just lovely.
The problematic bit is that EWs I have are 15ohms each.
If I wire 4 in parallel it will give me just under 4ohms on each side.
If I go 2 parallel 2 series, it will be 15ohms.
Are these resistance points workable in the crossover.
Should I try to find 4 more EWs to have 3/3 parallel/series on each side? (6 woofers on each bass box)
That would make 10ohms per side, a better load?
