Connections for V2
0 Members and 1 Guest are viewing this topic. Read 2343 times.
shadowlight
Connections for V2
« on: 29 Oct 2011, 07:48 pm »
Hello,
Need some help in trying to figure out how to hook up the V2 especially the woofers.
Here is what I understand:
Source --> PreAmp --> Amp --> Tweeter --> Woofer (Hi In)
Danny Richie
Re: Connections for V2
« Reply #1 on: 29 Oct 2011, 09:01 pm »
Two ways:
1) Source -> pre-amp -> amp -> V-2 speaker input
and Source -> pre-amp -> amp -> SA-1 speaker level input
So you basically come off of the speaker input at the V-2 and run jumpers over to the SA-1 amp, or Y the output from the amp with one pair of speaker cables going to the speakers and one pair going to the SA-1 amps.
2) Source -> pre-amp -> amp -> V-2 speaker input
and Source -> pre-amp -> SA-1 using low level input (RCA's).
shadowlight
« Reply #2 on: 29 Oct 2011, 09:34 pm »
Thanks Danny.
I realized that I had two outputs on the preamp so here is what I did, which seems to be working.
Source --> pre-amp --> amp --> v2 speaker input
Source --> pre-amp --> y-splitter for left right --> SA1 amp --> rca (left/right) input
and the sound is wow :bowdown:
shadowlight
« Reply #3 on: 3 Nov 2011, 12:42 am »
How does one go about level matching the tweeter and woofer portion?
jtwrace
    • TIPP YouTube Channel
« Reply #4 on: 3 Nov 2011, 12:59 am »
Mic
shadowlight
« Reply #5 on: 3 Nov 2011, 01:05 am »
Mic
Ok, I have a Mic now what do I do with it?  Any recommendation on software tools to use?  Will REW work?
jtwrace
« Reply #6 on: 3 Nov 2011, 01:06 am »
REW or HolmImpulse
shadowlight
« Reply #7 on: 3 Nov 2011, 01:16 am »
REW or HolmImpulse
Thanks.  Will run some sweep over the weekend.
Danny Richie
« Reply #8 on: 3 Nov 2011, 01:28 am »
I set my crossover to where about 90Hz would be on the dial. Set the phase to 180 degrees out. Then set gain as needed or wanted. I like to find a balanced sound and use several known references to check for the right level.
