0 Members and 1 Guest are viewing this topic. Read 14262 times.
Interesting. I got the T51p today, the look-alike cousin to the DT-1350. Also 80 ohms I think, also somewhat inefficient. Sounds very different - the T51p is very dark, somewhat muffled without EQ, then EQ'ing is difficult due to a big 10 db or so spike at 5 khz (compared to the other 12 headphones I use).
I don't remember if you have the DT1350 refresh version. Is that the same as 'CC'? If you already have it, the more ideal solutions are 1) Run from D3 only to eliminate all those suffocating connections and extra devices, or 2) Find a real tube/valve headphone amp. If your DT1350 is the original version, I imagine the new earpads would be night and day different.
The best thing I found in open air is going to seem a little peculiar here, but this is it: I got the Shure 1440 and cut the foams (Note: genuine Shure foams) off the back of the spare earpads, then stuffed those foams neatly into the earcups to smooth out the treble. But it wasn't quite enough I thought, so I got another set of replacement earpads from Shure and added those foams too. Actually, to get the third layer into the earcups neatly I removed the first one I added and then tucked 2 foams together neatly into each earcup. Now the treble was really, really smooth - and still quite detailed. I have a video on that that I need to repost.
I think the 990 should smooth out on each system you use it. There's a guy who has a blog for reviews called noblehifi (I think that's accurate) - name is Edd, and he's the king of Beyerdynamic reviewers from everything I've read. He generally prefers the 880 from what I remember, but his review or reviews of the DT990 would be well worth looking up.
I hear something playing in the background .... ummm .... it's Mad Dog by Mr. Speakers.
Whereas, the 990 with Fostex pads are mind melting and terribly hard to remove from head because of how good it sounds.I own the 990's. Very interesting indeed.
Well, I shipped the DT1350s back to big river today. I should receive a Hifiman HE-500 tomorrow.
I'm guessing you'll probably really enjoy the HifiMans...I know many people on head-fi who feel the 500s are the best in the hifiman lineup and compete favorably with some of Audeze's best offerings.
